Stumped. Error T06-606 on RP3700
  • pttrnlanguage
    • Jan 2012
    • 10
    [Error Code] Stumped. Error T06-606 on RP3700
    I'm totally stumped on this one.
    Error is something to do with horizontal pulse motor lock. Error point 606:
    "The horizontal-centering sensor does not switch ON -> OFF even when the horizontal pulse motor is moved 10 mm in the OFF direction."
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Stumped. Error T06-606 on RP3700
    Check the drum connector on the drum. Has the plastic gotten damaged? Are any of the pins bent or missing?
    • pttrnlanguage
      • Jan 2012
      • 10
      You know what, I did notice that one pin looked misaligned. I'll check tonight. Good tip!
