Risograph tr1510 scanning to legal size (8.5"x13")?
  • legaspiclg
    • Oct 2011
    • 72
    [Misc] Risograph tr1510 scanning to legal size (8.5"x13")?
    Hello,
    Good day, i have a RISOGRAPH TR1510 to which i can print only on A4 size, is there any configuration on this machine so that it can print to legal size(8.5"x14") bond paper?
    Thank you very much.
    Cesar
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Risograph tr1510 scanning to legal size (8.5"x13&quot?
    sounds like you are in need of a drum with a screen that will allow you to do paper longer than the A4.
    some times you can just replace the screen with a different one, but I would recommend that you locate a second drum unit for this machine.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • legaspiclg
      • Oct 2011
      • 72
      hI Mr. Shadow,
      Thank you very much for your sound recommendation, but when i check the drum, there is some space for the cloth to be printed, maybe the scanning is for the A4 size only? I am very sorry as i am only a new tech on this machine.
      Thank you very much anyway,
      Regards,
      Cesar
      • Shadow
        • Sep 2011
        • 455
        it is not the silk that determines the length of the paper, there is a screen behind the cloth. that screen needs to be of the correct length of image transfer for it to print on to anything larger than A4.
