Riso ComColor 7010 error S03-2007-2
+ More Options
Posts
  • Kopytek7
    • Mar 2012
    • 10
    [Error Code] Riso ComColor 7010 error S03-2007-2
    Keep getting S03-2007-2 error, checked lower BP Sensor, it's ok!
    Ran 1182 BP loose wire detect, OK
    When I ran 2405 in maintance mode it gave me a W70-0247-3?
    Can not get past the S03-2007-2, it is not bottoming out, added black tape to the flag to see if maybe not going down far enough. Any help is appreciated, case you didn't know, not certified on this machine!!!
  • dara
    • Sep 2008
    • 26
    Re: Riso ComColor 7010 error S03-2007-2
    OK seems something is wrong with your Lower limit sensor. When the belt platen comes down to lower position the sensor went ON then OFF. (Possible sensor chattering or sensor came off position)
    If error message W70-0247-3 comes up, press the Close key to let the machine make the printout.
