I have a problem with HC 5500 (wire type). The yellow print gives white lines. After cleaning the heads the white lines disappears, after printing 50 pages the white lines appears again. And it gets worse.
I performed cleaning heads and I even did manual cleaning the heads with a wipe stick. Also checked the temperature of ink in LD Unit, it seems ok (33-33.7 degree).
Is there anything else I can do? Or should I replace the heads?
Thanks in advance.
Thanks in advance.
