Floating print position
  • LA TECH
    • Sep 2010
    • 91
    #16
    Re: Floating print position
    the gunk might be because the rubber ring between the solenoid and the plunger has become all sticky and soft. good thing you were able to get that hook welded, but I would replaced it because it has to have certain distance with the bracket or you will be putting extra pressure on the drum
    • ddude
      General Troublemaker
      • 473
      #17
      Originally posted by smallprintds
      I just used a small wire feed welder to add a lil' metal where it was gone. And the thing that freaks me out is that I did it with the hook in the machine! Good thing I didn't zap the computer or some other important part.
      Better to be lucky than good...
      And LA TECH, thanks for the advice!
      Are you sure that you're not a tech? You have the talent and inquisitiveness to be technician material-
      2000 mockingbirds = 2 kilomockingbirds
      • smallprintds
        • Dec 2007
        • 25
        #18
