SC 03-00 Gestetner 5490+
  • justmynick
    • Jun 2025
    [Error Code] SC 03-00 Gestetner 5490+
    Hi all, my first post here.
    I own an old gestetner 5490+, since yesterday when i try to print the master the copier give me a service call SC03-00.
    I am capable to see the SC menu [yellow "clean all" button, then digit 107 and then press the red/stop button for 5 sec] but i am not able to do anythingh else...or at least i don't wonna do whitouth proper knowledge.
    I don't know what that code meaning, and how to clean it by myself, if is possible.
    Any help will be higly appreciated.
    best, and
    greetings from Italy
  • staffie man
    • Aug 2011
    • 59
    Re: SC 03-00 Gestetner 5490+
    best, and
    The sc code indicates a thermal head ID issue, never had this fault but manual states MPU problem.
    • Bantams
      • Jun 2012
      • 603
      [q]Thermal head ID
      error
      The CPU detects an abnormal ID
      signal from the thermal head.
      Defective thermal head
      Defective MPU[/q]
      Very Expensive and Probably the Thermal Head needs replacing if you can manage to Obtain One
      • justmynick
        • justmynick
          Originally posted by Bantams
          [q]Thermal head ID
          error
          Defective MPU[/q]
          thank you too Bantams,
          sounds very bad
          the strange thing is that sometimes it can make a master [one time of 100 try]
          • MobileTechy
            maybe look on internet for a used inexpensive copier with same make and model number .. use for parts
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
