riso rp-3105ep error code A17-999
  • gobby bobby
    • Jul 2025
    Any help will be greatly recieved.
    the error code says its a master jam, their is nothing jammed.
    absolutely nothing will work, key pad, the drum wont release.
    I made a new master, the machine printed 1 proof off as normal, then said their was the error code
    any ideas please ?
    ps
    how do i lift the scanner head up higher, coz if i bang my head on it 1 more time, it might be hammer time
    many thanks
    gobby
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: riso rp-3105ep error code A17-999
    The code is a cutter error. There is no 999 error point for this code, its either a 221, error occurred durning recovery movement, or 209 cutter home position was off at start of master making. Try turning off the riso, hold the reset button down while turning on the riso. If that doesnt help then you may ned a new cutter unit. Good luck.
    • JustManuals
      • Jan 2006
      • 9838
      Riso Network Printer RP Series Parts & Service Manual - $12.77 : Just Manuals, The Internet's largest selection of manuals ~ Instant Downloads
      $12.77 and instant download.
      Paul@justmanuals.com
      • gobby bobby
        already got the manual, and ive read it, but it tells me nowt
        thanks for the reply ill try your suggestion
        • gobby bobby
          thanks buddy, ive tried this and still nothing, anymore advice ?
          or is there anyone near me in the UK, south yorks / north notts, Sheffield region that can help ??
          • jermyth
            Riso dude
            • Mar 2011
            • 441
            Well since you got a manual try going into test mode, hold print position left & right keys down while turning on machine, and try running test mode 080: force clear jam, then 250: cutter motor cycle. If you can't hear the cutter then you got get a new cutter. Oh, and before doing this remove the master roll from the machine so you don't get pieces of master in the cutter, which might be what is causing your error too.
            Good luck.
