RZ220 paper jam
  • LennoxD
    • Sep 2011
    • 82
    RZ220 paper jam
    Paper jam under print cylinder. Paper sensor at registration test ok; pressure solenoid test ok. What I notice is that the pressure solenoid does not activate so jamming paper under cylinder. any suggestions? Thanks
  • andresbutiong
    Re: RZ220 paper jam
    did you try t clean the solinoid maybe this i stock up
    • jermyth
      Riso dude
      • Mar 2011
      • 440
      Re: RZ220 paper jam
      Check the one-way timing gear, if it is NOT red on the inside then replace it, RISO updated these on the RZs. If it is red then try cleaning it with alcohol and score the end of the timing roller shaft it runs on. Good luck.
