RZ 390 master loading issue
  • ldfrepairs
    • Oct 2012
    • 148
    Master is not been fed fully towards the clamp plate. Only about 4 cm is fed out. Tested master load pulse motor and in test mode it works fine. Any suggestion on how to correct issue?
    drugstore-onlinecatalog.com
  • Iowatech
    Not a service manager
    • 3930
    Re: RZ 390 master loading issue
    Holding down the "Reset" key while turning on the machine sometimes helps.
    • ldfrepairs
      • Oct 2012
      • 148
      Nothing happened when I held down the reset button while powering up Riso.
      • ddude
        General Troublemaker
        • 473
        What does the Riso do when the master fails to feed? Any error codes? does it happen every time?
        2000 mockingbirds = 2 kilomockingbirds
        • ldfrepairs
          • Oct 2012
          • 148
          The error code that is displayed is A16-525. Master has already been removed and load is in process but the master is not fed out sufficiently under the clamp.
          • jermyth
            Riso dude
            • Mar 2011
            • 440
            That code says "waiting for the master to be removed from the print cylinder". My guess is the master removal sensor is dirty or master stuck under the clamp/ on the felt of the drum.
            • Khumz
              • Feb 2020
              • 63
              Hello..
              I know this an old post and i have already posted about my problem. What i want know is did you find help to resolve this problem? I m experiencing the same problem as yours. Please send me any post that were of much help to this problem.
              • lucas020
                • Jun 2023
                • 3
                Troubleshooting the master feed issue is crucial. Since the master load pulse motor functions correctly in test mode, focus on the physical components. Check for any obstructions in the feed path and ensure proper alignment. If the problem persists, seek quantitative analysis homework help to employ a systematic approach in diagnosing and resolving the issue. Expert guidance can provide insights into the quantitative aspects of troubleshooting, enabling a more accurate and efficient resolution to the problem at hand.
