Wiered Problem in Riso ks800!!!!!!!!!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    Hi to all
    i have problem in riso ks800 , when i turn switch On and make paper in scanner ! when i pressing start the scanner doesn't pull the paper and the machine block and does not move anything !
    What is the problem and do you have any one have idea !
    Thank you in advance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    Re: Wiered Problem in Riso ks800!!!!!!!!!
    Any one can help us to resolve this problem!!
    DAMENE ABDEL AZIZ
    DJELFA
    • Shadow
      PHD in Sh!t Disturbing
      • Sep 2011
      • 455
      when you load the document feeder, does it indicate that there is paper there?
      have you tested the sensor to see if it works?
      did you check the clutch/motor for the paper feed?
      what have you done to this point?
      are you referring to the service manual?
      $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
      • JustManuals
        • Jan 2006
        • 9838
        This Service Manual can now be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • sweet.persona
          Engineer
          • Nov 2009
          • 414
          Thanks friend
          Shadow and Paul for ur reply ,
          i have cleaned all the sensors but nothing!! when i put document and ^pressing start Nothing moves!!!
          DAMENE ABDEL AZIZ
          DJELFA
          • LIOEEK
            • Oct 2012
            • 22
            There must be some kind of code that prevents the machine to make a master. are there red lights on the panel? can you manually rotate the drum with the lever?
            • sweet.persona
              Engineer
              • Nov 2009
              • 414
              Thanks Dear Friend
              There is No red flash At the Panel , but when i rotate the Clamp motor sometimes that scan half paper And displaying up E003
              i have cleaned all the sensors in the calmp motor section But without reslut
              DAMENE ABDEL AZIZ
              DJELFA
              • LIOEEK
                • Oct 2012
                • 22
                Have performed 64 on testmode? maybe its time to replace the clamp unit.
                • LIOEEK
                  • Oct 2012
                  • 22
                  Have you performed 64 on testmode? maybe its time to replace the clamp unit.
                  • sweet.persona
                    Engineer
                    • Nov 2009
                    • 414
                    yes i did changed the clamp motor section but without result!
                    DAMENE ABDEL AZIZ
                    DJELFA
                    • Shadow
                      • Sep 2011
                      • 455
                      have you checked all the sensors and feed unit of the master section?
                      are you sure it is feeding out the master?
                      • sweet.persona
                        Engineer
                        • Nov 2009
                        • 414
                        Thank you friends
                        problem resolved i found that the Clamp motor Does't rotate when i pressing start Button.
                        DAMENE ABDEL AZIZ
                        DJELFA
