Riso GR2710 Problem!!!!!!!!!!!!!!!!!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    Hi to all
    i have Riso GR2710 i cannot printing and at time when i turn power On all Buton in panel does't commad and i see led of master flashing !:
    i have cleaned all sensors and Master section but without result , The following image shows the problem IMG592.jpg
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    Re: Riso GR2710 Problem!!!!!!!!!!!!!!!!!
    Can anyone Help me!!
    thank you in advance.
    DAMENE ABDEL AZIZ
    DJELFA
    • Iowatech
      Not a service manager
      • 3930
      Have you reset the machine by holding down the "Reset" key while turning the machine on, and continuing to hold it down until the initializing motor sounds get quieter? That will take care of a lot of mystery problems if there are problems with the environment or the electric utility. Although you probably should only do that once per problem.
      Also, you might want to make sure that the covers that you need to open and close to replace the master roll are in good shape.
      • jermyth
        Riso dude
        • Mar 2011
        • 440
        C42 is replace master roll message. If the roll has been replaced recently then try resetting the master material under the green master feed. Make sure master making unit is closed completely. Good luck.
        • sweet.persona
          Engineer
          • Nov 2009
          • 414
          Thank you friends
          but how can i reset it!!
          DAMENE ABDEL AZIZ
          DJELFA
          • sweet.persona
            Engineer
            • Nov 2009
            • 414
            Please , how can i Entre to the TEST MODE i tryed much time to pressing PHOTO/LINE and M bouton with P bouton but witout result please i want clear explain
            DAMENE ABDEL AZIZ
            DJELFA
            • jermyth
              Riso dude
              • Mar 2011
              • 440
              You do not need to enter test mode, rewind the master material, turn off the riso, hold the resest button down and turn on. Read some older posts, they give the same info.
              • sweet.persona
                Engineer
                • Nov 2009
                • 414
                please i need to entre TEST MODE explain to me !!
                DAMENE ABDEL AZIZ
                DJELFA
                • jermyth
                  Riso dude
                  • Mar 2011
                  • 440
                  Please explain to me why you need in test mode for a end user error code? Or is there something else you're not talking about here. Im willing to help but I need more info as to why. And if you need in that bad, buy a manual. I bet Manuals4you can sell ya one.
