RISO CZ100
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] RISO CZ100
    hello i have CZ100 the costumer was add a new ink cartridge original ...but unfortunate if i started there a copy i show this ...i clean all parts of drum ...but nothing ..pls can anyone have idea ..DSCI0001.JPGDSCI0002.JPG
    BEST TECHNICIAN . NICE PEOPLE .
  • 20gaugeO/U
    • 557
    Re: RISO CZ100
    If the machine has sat idle for a while these streaks will happen. Run 50 copies on slowest speed (do not make a new master). If that doesn't work. Take the master off the drum and clean the drum screen with whatever solvent you use (alcohol, belt cleaner, simple green) to open up the pores. Make and new master and run copies. It should fill in. If not you may have to clean the drum shell under the screen.
