Riso RN2235ui error code T98-005
  • Predsboro
    [Error Code] Riso RN2235ui error code T98-005
    Good evening ... having an issue with a RISO (imagine that) RN 2235ui. Error code is T98-005 ... anyone familiar with this code and if there is a work around? Thank you in advance ...
  • ddude
    General Troublemaker
    • 473
    Re: Riso RN2235ui error code T98-005
    I think that T98 is a drum set error- might have ink leaking into drum connector? Do you have a different drum to try?
    2000 mockingbirds = 2 kilomockingbirds
    • jermyth
      Riso dude
      • Mar 2011
      • 440
      T98-005 is listed as a hardware error(that's all the manual says). Try turning off Riso, hold the reset button down and turn on while holding the reset (number 1 riso fix). Good luck.
