Greetings and salutations.
I seem to be having issues with our HC5500 jamming. It started randomly jamming when duplexing, Then progressed to always jamming when duplexing. Now it is jamming when the first sheet passes under the “emerge detection sensor” and gives X02-223 H1 jam. I removed the paper and checked all the sensors in Service Engineer mode 8.2.4.# and they appear to be registering properly when tested. The paper we are using is standard office paper 20LB we are running it 11X8.5 I did try switching the orientation but that had no effect.
EDIT: I would also like to add that we are now getting X02-223 H2 errors and it is dog earring the corner of the sheet on the lead edge operator side. when feeding through the Standard feed tray. When we try to print from the Trays we get X11 429Our currently humidity is 41% drybulb
Series of events that may or may not help:
The equipment that I am falling in on has never had any preventative maintenance done to it so it needs some TLC (different story for a different day) At first our sheets were being printed very skewed. We adjusted the speed (menu 8.3.2) and that was fixed. Almost immediately after that we had received an error s02-300. I remember from my training that this can be caused by the ink pan shafts needing lube. We found the shafts were bone dry as if never lubricated, after lubricating the error went away and then we noticed we were unable to print duplex. The unit would give a jam error whenever the first sheet would pass through the switch back and pass the CCD (where it is currently jamming on the first sheet.)
If any of you guys would be able to assist me it would be greatly appreciated. I am more so used to repairing on the Offset presses rather than digital duplicators and the fact that I am chasing my tail and getting different error codes makes it hard for me to pin point what is wrong.
