RISO RP 3105ep T96-552
  • papmet
    [Error Code] RISO RP 3105ep T96-552
    I have error code t96-552 i try to fix it in test mode #80 then action and reset so i got new one t95-056 ... anyone can help me i have no idea how to fix that problem. Thanx for interesting
  • Iowatech
    Not a service manager
    • 3930
    Re: RISO RP 3105ep T96-552
    What happens if you run test mode 80 again?
    • papmet
      Thank You for interesting so, if I run test mode #80 again i got in rigth bottom cover number 201 then I click 80 green yellow and number t95-056 or t96-552 it's that's all and my riso is not run that's all what i know. but one time i got screen with error d02-532 so i run test mode #80 again and back to the first error that mean t96-552... it's sad but true and i'm in big trouble becouse of that can You give me little advice what more i can do ??
      • jermyth
        Riso dude
        • Mar 2011
        • 440
        t96 is a drum pcb error. Pull out the drum and check the connector on the drum and the riso. Look for damaged or missing pins. Try a different drum if you have one.
