How to find the IP address? RP 3700
  • youwithrhinestones
    • Mar 2013
    • 23
    Hello,
    I am trying to network my RP 3700 to my PC running Windows XP. I've download the drivers from RISO's website and I am trying to install the printer via the instructions on: https://dl.dropbox.com/u/7145725/rp_manual_en_200.pdf but I can't seem to locate the printers IP address needed to setup the proper ICP/IP port. Not sure if my printer already has an IP address or if I need to assign it an IP. Any thoughts are appreciated.
    Thanks!
  • HenryT2
    • 962
    Re: How to find the IP address? RP 3700
    I don't work on RISO's , but , try printing a Network or Service Status sheet ( if these printers have that capability ) and possibly the IP will be listed. If you can print a Menu Map, it may be there as well .
    Good Luck .
    You should also try this question in the OTHER BRANDS sections in the "Copiers" and also in the "Printers" . You may get more responses to this question .
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
      • Mar 2013
      • 23
      Thanks HenryT2. I know there is spec sheet you can print when using a RIP, I'm still trying to find out how to do one if I'm printing through a network from my computer. I'm gonna try and run the printer through a router and assign it an IP using DHCP. I'll definitely hit up those other forums too.
        • Mar 2013
        • 23
        Looks like the only way to assign my RP3700 an IP address is with the RISO Utility Software CD...which I don't have. Does anyone know where one might acquire the software either via download or purchase the CD?
        • HenryT2
          • 962
          Check with Paul on that ...
          Paul@justmanuals.com
            • Mar 2013
            • 23
            Found it! It was on http://download.riso.com/ under the embedded controllers drivers. When it asked for the model I was only looking under RP 3700 but once I further researched the options there was an option called "net card" which is the download for the RISORINC software. Gonna test it out tonight.
