Hello,
I recently got a GR 3750 and I'm having a few issues with it.
The biggest issue is that my color drums don't print as well as my black drum. The black prints well and solid, but the color drums are pretty light and patchy. I've tried cleaning the drum screens with Armor All Cleaner & Degreaser, which helped some. I got the drums from someone who hadn't used them in a while and which had been in an unheated / uncooled garage in Indiana. I attached images of two gray scale tests made from the same laser printed original.
The second issue I'm having is a white stripe in the images, spaced about 60 mm apart, which I notice is about 1/2 the circumference of the impression roller (or whatever you call the roller that puts the paper in contact with the drum).
The third issue is that I have trouble feeding regular 20 lb. copy paper. It inevitably feeds up to 5 sheets at once. Using heavier paper, like 100# text weight, it feeds fine.
Any suggestions would be most appreciated!
Thanks!
Daniel
Thanks!
Daniel
