Ricoh JP5000 Japanese on the LCD
  • maximilian
    • Aug 2025
    [Electrical] Ricoh JP5000 Japanese on the LCD
    Hello!
    I found out that it is necessary to replace the RAM chip M48T58Y-70PC1.
    But there are a couple of points...
    Replacement of the IC will be enough or some of the procedures needed, such as:
    1. updating firmware
    2. system & copy image adjustment
    3. calibration
    Ps the priport operation of a normal, except for the language, time, etc.
  • Bantams
    • Jun 2012
    • 603
    Re: Ricoh JP5000 Japanese on the LCD
    They come Default as Japanese because the Boards are made In Japan so are the Machines funny enough all you have to do is change the Default language from Japanese via sp mode xxx x to whatever language you need Try English
    • maximilian
      Yes, if it was that easy http://www.copytechnet.com/forums/im...rin.pngSetting is not saved after shutdownbattery back-up data storage in chip M48T58Y-70PC is faulty http://www.copytechnet.com/forums/im...lies/frown.png
