E-06 Main Motor Lock The CPU cannot detect the feed start
timing sensor signal within 2 seconds after
the main motor turns on, or the sensor
remains on for more than 0.5 seconds.
Main motor
Power to the main motor
Feed start timing sensor
Mechanical interference with
the drum drive
You will need to replace the main motor control board. Take of the back cover and there is a small circuit board. It's the only board you can see. It's green, held on by three screws.
