Risograph RP3700 !!SYSTEM ERROR!! T14-150
  • seadreams
    • Jul 2025
    [Error Code] Risograph RP3700 !!SYSTEM ERROR!! T14-150
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Risograph RP3700 !!SYSTEM ERROR!! T14-150
    Scanner flatbed error. Timeout error for receiving the risograph scanner command.
    1. try turning off, then on.
    2. hold reset down while turning on.
    3. check wiring harness to scanner, unplug, plug. Pinched wire, loosen wire tires or remove them.
    4. get tech manual.
    Good luck.
    • seadreams
      Thanks so much! It seemed to work when I switched it on and off with the reset button pressed.
      Could you tell me where I could get a service manual for this machine?
      Regards,
      Josh
      • jermyth
        Riso dude
        • Mar 2011
        • 441
        I believe justmanuals.com can help ya. Paul the owner posts on here and has paid ads in the banners.
        • umar
          • 18
          Hi,i have problem with RN 2530AS.
          When i turn ON this machine,display show T98-005.
          When i push * key, its show T98-005 & T14-160
          Any ideas?
          Thxs,
          Umar
