RN 2530AS
  • umar
    • 18
    RN 2530AS
    error accours T98-005 & T14-160
    wire harness & other connection ok
    need advice please...
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: RN 2530AS
    Check if the scanner will move in test mode. If not recheck wires, harness, undue cable tires (pinched wire).
    Good luck.
    • umar
      • 18
      Re: RN 2530AS
      The scanner dosn't move in test mode. I already check the connection it's ok.
      Before the machine had system n drive in version 3.12
      Now it had system n drive ini version 1.59
      It's that take effect?
