Riso LCD touch screen unresponsive
  • risopdx
    • Jun 2025
    I'm having issues with an unresponsive touch screen on an RZ990U risograph in my print shop. The display boots to the intial mastermake/print select screen but its on-screen buttons won't respond to touch commands. However, I can advance to the mastermaking/printing screens by pressing the mechanical green start button on the right panel.
    The touch screen has worked fine since I bought the riso used last November. I've only had a few instances of sticky LCD buttons that initially won't respond to touch. However, the LCD hasn't been responding to ANY touch functions for the past two days.
    Anyone else had problems with touch screen sensitivity? Is there a way to recalibrate the touch screen, perhaps from test mode? I'm looking at the service manual under "Protected Area Test Mode" and it appears there's a function for "LCD Base Point Compensation." I'm wondering if this is used to recalibrate the screen.
    I'd like to do everything I can before looking into replacement parts.
    Thanks!
  • jermyth
    Riso dude
    • Mar 2011
    • 438
    Re: Riso LCD touch screen unresponsive
    I have not see this problem, but sounds like trying that TM would be my first step. After that, check connectors and wires. I did see a You tube video a year or two ago about how to fix touch/lcd panels, but never got into it.
    Good luck.
    • umar
      • 18
      Sure you have to calibrate the touch screen in Test Mode
      It's in LCD Base Compentation---start
      Touch every (+) appears on LCD--start
      After that,find TM to initialized the machine.
      Good Luck
      • steadythighs
        • May 2015
        • 6
        Did you end up figuring this issue out by chance? I'm having the same, and have tried the TM calibration to no avail.
