Hi, thanks in advance for your time. My riso 390rz is not feeding constant, I clean the paper sensor, also the sensor under the timing roller and I cleaned the clutch area same with the rubber feed roll, mean feed area, if I run at reg speed is jam after 3 or 4 sheets but blowing some areas around feed area I run at minimum speed and running well some jam after 100 or more, any advice
Rico 390rz
Re: Rico 390rz
If that is OK and the machine continues to misfeed, sounds like the feed rollers and separation pad need to be replaced.
