Riso GR3750 Image Adjustment?
  • ybnews
    • Oct 2008
    • 94
    My Risg GR3750 has an issue.
    Every master I make on Any cylinder I use the image prints more than 1 inch to the right of the lead edge. There's not enough range in the "print position" button to compensate for that discrepency.
    How do I determine if it's the cylinder alignment, timing or scanner that is out of sync?
    Thank you,
    Dana
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Riso GR3750 Image Adjustment?
    Get a manual and check the timing in the back. There are holes and cut outs that need to line up 1st. Then there is a procedure for adjusting the registration. These may have been listed in a previous thread or two on how to.
