Check Paper Feed Area Error Code
+ More Options
Posts
  • racheldavey6
    • Jul 2025
    [Error Code] Check Paper Feed Area Error Code
    Hi!
    We recently bought a RISO GR3750. After turning the machine on the error code "check paper feed area" comes up and will not go away.
    After cleaning, checking for any obvious faults (broken wires etc) and speaking to a Riso engineer on the phone it sounds like its a problem with a jammed safety switch or the paper feed tray has dropped too low.
    However were not sure how to rectify this matter.
    Any advice or suggestions on how to fix it would be amazing!
    we just want it to work
    Thank you!
    Rachel and Lottie
  • JustManuals
    • Jan 2006
    • 9838
    Re: Check Paper Feed Area Error Code
    Paul@justmanuals.com
    • racheldavey6
      We have a manual, but it doesn't go into specific detail about this particular error message.
      I know its hard to offer advice without seeing the machine but any insight into this issue would be wonderful.
      thanks
      • Iowatech
        Not a service manager
        • 3930
        thanks
        Have you tried searching this thread for answers? There is loads of extremely useful information here.
        Also, as far as manuals go, the user manual would probably be far more useful than the service manual for this.
        • racheldavey6
          Hi,
          which thread are you referring too?
          We have the user manual, and it recognises the error message but merely says "make sure paper feed area is clear", which on the surface it seems to be!
          • Exok
            • Jun 2011
            • 750
            Doing a google search for "RISO GR3750, Check paper feed area error code gives these results. Maybe one of them will help you solve your problem.
            http://www.copytechnet.com/forums/di...feed-area.html
            http://www.copytechnet.com/forums/di...tor-stuck.html
            http://www.copytechnet.com/forums/di...ed-repost.html
            • Iowatech
              • 3930
              Hi,
              I'm referring to this thread right here that you are posting to. There is all sorts of useful information that will help you out with this problem. You should search it.
              Oh, cool, you do have the user manual. So is the paper feed area actually clear? Can you provide pictures?
              Thanks!
