rz220
  • cleardata
    • Jul 2011
    • 137
    rz220
    hi to all,
    i'm quite new with risograph and the machine has an A34 218 error and based on the manual it says "request to resetting the master". number 3 is also lit but my problem is i can't pull out the drum unit nor the master because the green light won't turn on. both the drum unit and the master are locked.
    please help.
    thank you.
  • jermyth
    Riso dude
    • Mar 2011
    • 440
    Re: rz220
    Try holding the reset (yellow button) while turning on machine. That may clear the error to let you open the master unit. If not, then you will have too cheat the lock, screw driver into small hole under handle to unlatch while opening/ pulling out master unit.
    Good luck.
    • cleardata
      • Jul 2011
      • 137
      Re: rz220
      Good luck.
      thank you very much jermyth. i'll try your solution.
      best regards to all.
