Risograph RP 3700 A16-525 Master Probl.
  • inuit
    • 14
    [Error Code] Risograph RP 3700 A16-525 Master Probl.
    Hi,
    It's me...again...(I'm not a lucky Risoguy).
    I recently got another Riso RP 3700 in not-so-great conditions. After so (much) time I've cleaned all the machine and changed some parts (some rollers, screws, rubber belts etc..).
    Well:
    • The machine starts, makes all the correct riso-mechanical-adjustment noises
    • the scan works well
    • the paper tray detect if there's paper or not
    • if there's a drum inside with master on the machine do as many copies as you want
    • if you tell it to make a master, it unrolls and burn the master correctly
    BUT:
    It gives this kind of ERROR CODE: A16-525 (Master remains on print drum) even if there's no master on the drum.
    So you'll find the new master (with the image perfectly burned on it) all shrunken in the master disposal box.
    What I tried manually:
    • searched a lot on google/forums but found nothing helpful
    • power ON/OFF the machine multiple times
    • removed and changed (with a functioning one) the Master Loading Sensor(C)+Master Positioning Sensor(D)+MasterMaking Unit Sensor(E) [Fig A attached]
    • removed and changed the Sensor Bracket (B) [Fig B attached]
    • Removed and changed the Position-B Sensor Ass'y [Fig. C attached]
    What I tried in Test Mode:
    So: the machine able to see if there's a master on a drum (and consequently can print perfectly) BUT if there's no master on the drum it say there is one (so produces a new master but is unable to put it on the drum).
    Hope what I've written can help you to help me.
    Thank you,
    Marco
    A -Riso MasterLoadingSensor.jpgB - Riso SensorBracket.jpgC- Riso PositionBSensorAssy.jpg
  • jermyth
    Riso dude
    • Mar 2011
    • 437
    Re: Risograph RP 3700 A16-525 Master Probl.
    Open the unit (scanner up), cheat the safety switches, punch in to do a confidental master, watch what it does. Does the clamp open and eject the old master? Does it error after that? Does it put the new master on and then remove it? Good luck.
    • Iowatech
      Not a service manager
      • 3930
      Just clockwise from the master clamp, there is a black area on the drum. Make sure that is in good shape, as that is where the machine looks to see if the master removing process has completed properly.
      • RRodgers
        • Jun 2009
        • 1947
        Be sure your clamp is working properly as well. Shouldn't be any ink under it at all. This will cause it to stick.
        • jermyth
          Riso dude
          • Mar 2011
          • 437
          And I forgot to mention, check the white rollers on the clamp. No cracks or broken off.
          • Riso Tecky
            On the the drum its self there is a black felt part# 030-16241-104 light absorber sheet if that is missing the Riso will think that the master sheet is still on the drum, check to see if that's there they sometimes fall off the drum.
            • Iowatech
              • 3930
              Yeah, like I said earlier. Still, good call on the part number.
