Riso RZ 390 jamm
  • ops
    • May 2025
    Riso RZ 390 jamm
    Need help have error. J08 jam. I change tire and strip pad and also I clean paper sensor is running in slow speed one, but when I increase the speed is jam ? Someone say I need to change the cloutch what do you think is true. I have the service manual thanks.
  • kikinkuntry
    Certifiable technician
    • Mar 2013
    • 27
    Re: Riso RZ 390 jamm
    J08 is jam on drum. But the only path sensor between the tray and drum is the one before the drum. If it never tries to pull then yes try a solenoid. Make sure your sensor is in correct position under the timing rollers as well.
    I'd be happy to come out and wipe off your dirty glass. One question however, do you also pay someone to come out and wipe your dirty ...
    • Iowatech
      Not a service manager
      • 3930
      Can you provide a picture of what you are trying to print? Because it kind of sounds like you are trying to print something with a lot of ink on the leading edge.
      • ops
        Letterheads, just text upper, and small line footnote.
        • jermyth
          Riso dude
          • Mar 2011
          • 437
          RISO came out with a tech note on the feed cores failing. The old one part #023-12306 on it. New #021-14302.
          Those cores can give you all kinds of jams.
          Good luck.
