RISO RP3105 displaying T06-605 !!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    hi to all
    i have problem in riso rp3015 when i turn power on after abit they displaying T06-605 can any one explain !
    thank u in advance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: RISO RP3105 displaying T06-605 !!
    Horizontal centering sensor does not switch OFF -ON when pulse motor is moved 12mm.
    Sounds like a dirty sensor in the drum movement mechanism or a broken sensor.
    This is inside the drum unit. Could even be the horizontal motor.
    You have to open the drum to get to the sensor & motor.
    Good luck.
    Last edited by jermyth; 09-30-2013, 02:35 PM. Reason: more information on location.
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      hello
      thanks friend for ur reply
      i have checked the Horizontal pulse motor and i cleaned it , i cleand too the Sensor but No reslut!!!
      But finaly i found the B sensor position was damaged , i replaced New one and everything is ok
      DAMENE ABDEL AZIZ
      DJELFA
