Risograph GR 3750 Exit Belts Not Moving
  • barrywilder
    • Nov 2013
    • 11
    The belts in the exit area that move paper out of the machine suddenly stopped moving. I can move them manually, so they aren't physically stuck. The paper moves under the drum and gets printed, but then just sits inside the machine. Any thoughts?
    Thanks!
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Risograph GR 3750 Exit Belts Not Moving
    Two possibilities. 1, the one-way gear in the exit drive clutch gears is slipping. 2, set screw in gear on drive shaft in exit assembly has worked out. 2 is easier to fix and check, get a manual and see chapter on paper ejection on how to remove the assembly (too long to type). The one-way gear possibility is harder and the gear would need to be replaced. If you end up needing the gear, PM me I might have one.
    Good luck.
    • RRodgers
      • Jun 2009
      • 1947
      It's usually the set screw has backed out.
      • barrywilder
        • Nov 2013
        • 11
        Thanks for your replies. Strangely, after leaving the machine for a few days, the exit rollers suddenly started working again.
        • DAG COPIERS & COMPUTERS
          • Oct 2010
          • 860
          Strange indeed, replying to the post almost after three years.I suggest you still crosscheck the set screw and other related components.
