d02-532
  • atto
    • Jul 2025
    [Error Code] d02-532
    Hi, I bought a fluorescent pink drum on ebay for my RP3505.
    The description said
    NEW! Riso Risograph FLUORESCENT PINK Type RP Color Drum RP3505 RP3105 RP3700UI
    so I was pretty sure that this drum has fitted my copier, instead when I try to use the drum, the risograph return this error
    d02-352 wrong-type print drum installed.
    I wrote to the seller, and hope he will answer soon, but in the meanwhile i'd like to know if there's something I can do.
    Thanks so much
    andrea
  • Iowatech
    Not a service manager
    • 3930
    Re: d02-532
    You might try resetting the machine while that drum is installed by turning the machine off, then holding down the "reset" key for a while when turning the machine on. But only do that once.
    Otherwise, that drum is probably not programmed with the correct size or color.
    • atto
      Re: d02-532
      Iowatech thanks for your reply,
      I tried the reset but it didn't work
      Is there a way to understand if this drum is really compatible with 3505?
      A Risograph technician told me that probably this is a drum for rp37xx and the 37 series is not compatible with the 35 series,
      but in a lot of online shop those drums are sold as compatible with both series (here - where i bought - or here where there's no specification), why this happens?
      Is there a way to re-program this drum to make it compatible with my machine?
      Thanks for the support,
      andrea
      • Iowatech
        • 3930
        Re: d02-532
        andrea
        I'm not sure. If I remember correctly, the RP37 series prints 600 dpi, and the RP35 series like yours prints 400 dpi. That's probably why the Riso tech said the drum is incompatible.
        I've never tried swapping drums between RP35-37 series machines, so I don't know how much more help I can be. Any chance the place you bought the drum from can reprogram it?
        Sorry.
        • atto
          Re: d02-532
          I (to be honest the Risograph technician) solved the problem!
          He entered in the test mode (press right and left arrow while turning on the machine) and checked the setting of drums and colors.
          They were correct, but he re-setted them and the drum started to work.
          I took a picture of the table with color and kinf of drums, it's in italian, but it could be helpful.
          Thanks Iowatech for the support
          P.S. some drum for 37 are compatible with 35, as you can see in the table
