Riso RZ 390 drum problem
+ More Options
Posts
  • wawaloam
    [Misc] Riso RZ 390 drum problem
    There is plenty of ink in my yellow drum. It was master masters and printing normally until i lost half of the image. When I opened the machine the master is not completely stuck to the drum. and now I keep getting prompted to add more ink. How should i resolve this issue?
  • jermyth
    Riso dude
    • Mar 2011
    • 439
    Re: Riso RZ 390 drum problem
    If the machine has said to replace the ink, then the RF tag on the tube has been written to and marked empty. You have to replace the tube. As for the drum not inking all the way, check to make sure there isn't master stuck to the drum or something else.
    Good luck.
    • wawaloam
      Good luck.
      Thanks so much for your help! I am up and running again.
