Has anyone ever dealt with crooked masters being mounted to the drums on an MZ790?
So, on the drum - following the master from the clamp all the way around, it appears to be about 2-3 mm skewed toward the back (of the drum)
Attached a pic. I read a tech bulletin suggesting that repositioning the 'slide shaft' of the drum in one direction would correct the issue, but as far as I can tell it doesn't make much of a difference. I mean the masters still appear to be skewed...
I get it pretty consistently on both drums in both positions, which means the registration is still great! It's just that there is a visible skew across the page... I can live with it but if there is a way to fix it I'd like to know, I appreciate any insight, thanks!
