hello, Display says t3 on this model, How can I solve it? Any suggestions, thanks in advance.
riso fr291 error t3
Tags: None
Re: riso fr291 error t3
T3 is a master clamp error. Check the master clamp on the drum for damage or obstruction, and make sure the master clamp drive operates correctly.
If there was unreliable voltage from the socket you plug the machine into recently, there could have been a power surge that caused data corruption in the machine's working memory that caused the error code. So you might try resetting the machine by holding the "reset" key on the control panel down while turning the machine on, and releasing it when the sounds from the initializing motors gets quieter. Only do that once, though.
Hope that helps.
