Hello!
I'm back here for a question about the synchronisation of the printing with a riso gr3770. I understand that:
1) the paper feed synch should be set with the disk on the right on the picture (with the little notch aligned just above the sensor)
2) the printing timing should be set with the disk on the left (with the hole aligned with the sensor)
To move those disks, I managed to loosen the paper feed clutch and disengage the belt, I set the disk on the right like in the picture above, so when I fasten the paper feed clutch, it goes down a little and get the proper alignment.
BUT no matter where I set the disk on the left, it always get back to its initial position after one print like in the picture below:
Result: the printing stops too early... It should print until the red line in the picture (this is the end of the sheet)...
Any suggestion would be very appreciated!!
