Error p01 520 - risographe RZ-200ep
+ More Options
Posts
  • coco
    • Jun 2025
    (:Main encoder sensor does not go ON/OFF within 10 milliseconds after the main motor activates.). I've open the belly of the beast, but I can't find the problem.
    How should I do for repear it?
    Thanks.
    C
  • Iowatech
    Not a service manager
    • 3930
    Re: Error p01 520 - risographe RZ-200ep
    Have you tried resetting the machine by holding the "Reset" key down while turning the machine on? That can take care of some weird and unexpected problems.
    • coco
      Yes, I tried, but nothing; the screen shows "0", I press START, the motor starts to move but immediatly stops, and the error returns: the eternal p01 520.
      The error description talks about the main encoder that's not responding fast enough after the motor started to move. Do you have any idea about how can I fix that kind of stuff ?
      Thanks for your answer.
      Have a good day
      • 20gaugeO/U
        • 554
        If you can run the main motor by pressing the switch on the main board or in service mode 880 and everything sounds and moves good. I'd take the main motor out of the machine and crack open the sealed cover that goes over the encoder disc. One time I had enough dust get in there that it would throw this code. Or the main motor is bad. It's not that hard to do but you better know where all your timing marks are and have some jigs to lock them down.
        Good Luck
        • coco
          Good Luck
          Thanks, I try it.
