Customer called with RZ990 with error P98-947
  • axyun
    • Aug 2007
    • 1323
    Customer has error P98-947 on RZ990. Have no experience on this but read that this code is related to loss of 24v and could be due to blown fuse in group A. Your help is very much appreciated. Frank/ActionPhotocopy
  • jermyth
    Riso dude
    • Mar 2011
    • 440
    Re: Customer called with RZ990 with error P98-947
    Yeap. That's about as close you can get without getting into the machine.
    Good luck.
    • axyun
      • Aug 2007
      • 1323
      Thanks. Are you saying there is a good chance that it's the fuse? Is there something else I should be looking for that is common to this machine with that error code.? Frank
      • jermyth
        Riso dude
        • Mar 2011
        • 440
        Something is preventing the 24v, fuse is a first easy guess, but why did the fuse blow? You can't figure that out until you look at the machine and see what is or had happen. If it not the fuse, then did something else blow off the board or boards? I have not had this error in the RZ & EZ units I work on, so I don't have anything more direct for you.
        Good luck.
        • axyun
          • Aug 2007
          • 1323
          Thanks Gregory. I will probably see machine Monday or Tuesday, depending on customer. Have a good weekend. Frank
          • laitang
            • Nov 2012
            • 627
            Fuse F101 used to prevent 24V-A, that power for:
            Elevator motor
            Thermal pressure motor
            Cutter motor
            Read pulse motor
            Print registration pulse motor
            Load pulse motor
            Write pulse motor
            Suction fan
            Master stocker solenoid
            Pressure solenoid
            Print drum lock solenoid
            Paper feed clutch
            If the fuse blow when replaced, you should check electrical equipment in above list
            Good luck!
            • axyun
              • Aug 2007
              • 1323
              Thank you Laitang for the information
              • axyun
                • Aug 2007
                • 1323
                6.3a fuse for 24v was blown. Replaced and machine gave a message about the standard tray. Noticed preening on Rear elevation plate (024-12207-109). Also flat ribbon cable looked like it took a beating. I believe it is (024-12607-107) .
                Put everything back together to see what would happen after putting rear elevation plate back together as best I could. Now I get T98-129 error. Any help is appreciated while I try to order these parts from someone. Any help is appreciated. Frank
                • axyun
                  • Aug 2007
                  • 1323
                  Can someone recommend a company to buy parts from for the rz990. Also does anyone know why i would now be getting the error T98-129 which states in manual " defective scanner gate array pcb(memory check error on the gate array).
                  I didn't get this until I reassembled the broken elevation plate R and reinstalled the two sensors on bracket in back of machine which are used for detection when tray is elevated and descending I guess. Frank
                  • Iowatech
                    Not a service manager
                    • 3930
                    For what it is worth, it would be best if you got the parts from Riso. The mothership here tried to get stuff from elsewhere briefly, and failed.
                    T9X errors can be mysterious. Sometimes they are caused by the need for updated PCBs or firmware. Other times they are produced by poor quality power supplied by the outlet the machine is plugged into. If you can, look into the later reason first, from what I've seen it is likelier.
                    • axyun
                      • Aug 2007
                      • 1323
                      Thank you.
