MZ790 Horizontal print position / second drum print school
  • mixedfeelings
    • Sep 2010
    • 98
    Hi All -
    I have finally been fixing up and aligning an mz790 and I have run into a couple of problems:
    Horizontal print position:
    All masters are created with the horizontal position 1/16" - 3/32" to the right. I have tried adjusting the horizontal drum / main position using test modes using test modes 973 (drum) and 974 (machine) to no avail. Is there a way to change the center position of the TPH as there was with the RP models?
    Second drum skew
    The master has a clockwise skew, but is not substantial. I used the slide shaft to compensate for it and I got close - but i ran out of room to slide it any more - it's right to the edge. I have tried multiple drums, and swapped the drum positions and the first drum is always pretty good, but the second is always a little skewed. Are there other options besides the slide shaft? Is there a way to adjust the feed between the two drums? perhaps that path is where its going awry?
    Thanks!
  • Iowatech
    Not a service manager
    • 3930
    Re: MZ790 Horizontal print position / second drum print school
    Pictures, please?
    • mixedfeelings
      • Sep 2010
      • 98
      Hi Iowatech! I would gladly take a picture - what do you want to see?
      Thanks!
      • Iowatech
        • 3930
        Well, if you could pull the drum out after it made a skewed master and take a picture of the top of the drum cavity, that would be a good one. A picture of the skewed master on the drum or a print from one of them would be helpful too. And if you could open up the master making unit like you were going to load a new master roll, and take a picture of the master material being fed into the unit, that would also be helpful.
        • mixedfeelings
          • Sep 2010
          • 98
          • jermyth
            Riso dude
            • Mar 2011
            • 437
            Second drum position having masters getting skewed could be from the impression roller having uneven pressure on the drum. Does it happen with all drums used? I believe the adjustment for the pressure roller is in the manual, personal haven't had to do it.
            Good luck.
