I am getting a GR3750 up and running and trying to run some print tests but I can only run 1 copy at a time due to the "Paper Jam Check Paper Feed Area Error". I can do a reset to clear the error, print one copy and send a sheet of paper through.
The paper is not actually getting jammed - it seems like it is delayed as it gets picked up from the paper feed area. I have also checked and see no jams beyond of the single sheet print I am trying to run. Is this a timing issue? I am not getting any other errors - only the "Paper Jam Check Feed Area Error"
Also, there is hardly any ink on the drum - I gave it a good soak with de-solv-it citrus cleaner as the drum was pretty dried out.
If anyone can provide an approach to diagnosing this issue and resolving it would be greatly appreciated!
I have made two youtube videos showing the paper feed tray side and the paper receiving side to try to illustrate what happens when you try to print one copy. You will notice what I think sounds like a slipping/ skipping sound too:
I looked on the forum here and found these two posts about paper feed problems so wondering if it is some sort of timing issue as discussed here:
http://www.copytechnet.com/forums/di...ph-gr3750.html
and here:
http://www.copytechnet.com/forums/di...wont-feed.html
and here:
