Re: Thermal Print Head - Streaking
The roller was stuck in the furthest possible down position and was stuck. After wrenching it up the timing of the entire machine had to be adjusted - it looks like it had been tweaked and adjusted before.
Now the master is being written very close to the exit edge and stops about 1/2" from the back end of the image.
Link to video on Instagram: https://instagram.com/p/13JWPVmB8c/?...pjpjpjpjpjpjpj
Here are images (note only the yellow test code 80 pattern is what im talking about in the printed image)
Is there a way to adjust the write position // I read in the manual you had to adjust the clamp position as well.
When I enter the test mode to adjust the position (541) what does the input value mean? is it measured in mm? so if i type 20 does that mean 2 cm movement? I tried this and nothing really changed.
Any ideas? Model RZ310
Thanks,
PJ
Thanks,
PJ
