Paper wrapping around drum?
  • 7seas
    • Jun 2025
    Can anyone tell me why my paper would be wrapping over the print drum after it makes a master and then come up with the jam error J04?
    This is on an EZ370.
    I can take the paper off and the master is fine underneath.
  • laitang
    • Nov 2012
    • 627
    Re: Paper wrapping around drum?
    Check the air blown from the seperator?
    Check the gap between the print drum and the tip of seperator?
    • RRodgers
      • Jun 2009
      • 1947
      Heavy ink on lead edge?
      • 7seas
        Thanks for the suggestions.
        I tried adjusting the separator but it is still doing the same thing.
        Any other thoughts?
        • laitang
          • Nov 2012
          • 627
          Any other thoughts?
          Did you check the air blown from the separator?
          Did you check the air tube?
          Did you check the action of air pump?
          • RRodgers
            • Jun 2009
            • 1947
            Will it pass a blank piece of paper?
