Been running this GR 3750 for over a year with this problem and I would like to get it corrected if anyone knows the fix.
I position the 8.5 x 11 in the correct position on the glass and scan and make a master ... now when I run the copies I always have to use the "Print Position" adjustment to the + side to get it to make centered copies ... GR runs great otherwise and I know this is not normal as my RZ makes dead on copies with no Print Position adjustment needed ... what do I need to do to correct this?
Thanks in advance,
Dave
Thanks in advance,
Dave
