Black drum into colour drum
  • The Dark Knight Risos
    • Oct 2013
    • 13
    Can i make my black drum into a colour drum? I have a FR3950 (european). Can I change the settings? I want to make it hunter green.
    Cheers!
    • 37511
    Re: Black drum into colour drum
    If the black drum has already been used for black printing, I think you might find that the labor cost to clean all black ink from the drum and replace any parts that cannot be completely cleaned will be more than you are saving by not purchasing a new color drum.
    • Iowatech
      Not a service manager
      • 3930
      Cheers!
      I think you need to change the circuit boards and wiring harnesses in the drum to change the color of a drum on the FR line. And then run at least a couple of reams of paper through the machine until the color looks correct.
      I have never tried to change the color of a FR drum before though, so take this with a grain of salt.
      • jermyth
        Riso dude
        • Mar 2011
        • 441
        I don't think it can be done, the ink pump body is different between the black & color drum units.
        • mixedfeelings
          • Sep 2010
          • 98
          wouldn't you have to modify the tube? as jermyth said, i think the nozzle diameter is larger on the black drums - but also the "fin" is different?
          I mean, I have heard of it being done, but it seems like WAY more trouble than it's worth.
          • Exok
            • Jun 2011
            • 750
            Don't quote me but I heard it said that once you go black you never go back.
            • Jabilin
              • Jan 2015
              • 8
              • jermyth
                Riso dude
                • Mar 2011
                • 441
                Z series drums are different. It can be done. I believe its been posted on here before. Mostly got to change codes in test mode and run alot of ink through to purge out the old ink.
                Good luck.
                • Jabilin
                  • Jan 2015
                  • 8
                  I could not find the thread...
                  Do you know how to do it? Black Z drum into color.
                  I am also interested in a service manual (rz200 ) thanks!!!!
                  J.
                  Good luck.
                  • Iowatech
                    • 3930
                    You should have better luck searching the forum by using this:
                    Copytechnet Forum Search - Via Google
                    • maggan
                      • Sep 2016
                      • 7
                      I have the same question but about the RP 3105 EP and converting from blue to red. But I am willing to get the stripes for 1000 prints as an artistic choice.
