Riso 7050R BP Elevator
  • gfederas
    • Aug 2025
    [Error Code] Riso 7050R BP Elevator
    Wow. This is a really active forum. Thank you in advance for any help you can provide.
    I recently purchased a Riso 7050R. Brackets were correctly mounted before shipping and removed before initialization.
    The BP Elevator appears to raise and lower correctly, except the front contacts never close (rear contacts DO close).
    In test mode, 2405, 2406, and 2407 do not activate. What am I missing?
    Is there a recommended procedure to balance the BP so all four contacts are made? Are there any obstructions I should be looking for?
    Thanks.
