RISO ERROR A01-215 !!
+ More Options
Posts
  • crumbcabin
    • Feb 2015
    • 5
    [Error Code] RISO ERROR A01-215 !!
    Hallo !
    I ran test mode 557 with my blue drum , RP3105 machine.
    I have had issues with the drum, where it would make a new master maybe 1 out of 3 attempts. Now however it isn't making any.
    During the test mode 557 error message A01-215 popped up.
    After some research this is what is causing the issue:
    Description Faulty gate-array control for the write pulse motor (motor does not stop within set time)
    If anyone has any experience or idea of how I can solve this that would be really useful. Otherwise what I have been doing is making the master with my yellow drum and then attaching it to the blue drum, flushing the colour through in around 30 sheets then it works.
    But ideally I can get this fixed.
    Thank you!
  • jermyth
    Riso dude
    • Mar 2011
    • 438
    Re: RISO ERROR A01-215 !!
    If you can make a master on the yellow drum with no problems, then there is something wrong with the blue drum. Look and compare the clamps and drum connectors on both drums. My guess is something is broken on the blue clamp causing it to code out. But maybe the connector is not right either causing a communication error leading to the code. But normally that code has nothing to do with a drum, but I've seen weird things on RP units before so good luck.
    • crumbcabin
      • Feb 2015
      • 5
      Thanks so much for your help !
      I will check the connectors and compare tomorrow , hopefully can be fixed !
