Riso EZ 220 difference in supplies
  • Iowatech
    replied
    Re: Riso EZ 220 difference in supplies
    If I understand this correctly, the "cup" is where the RFID chip is located.
    If you can see things through core of the master roll other than the RFID chip, that master roll is not for your machine.
    Or at least use great caution if you must use it. There is a chance that stupid and wrong things will happen otherwise.
  • jermyth
    replied
    RZ220 & EZ220 & EZ221 all use the same master, S-4250.
    Good luck.
  • mdm
    started a topic Riso EZ 220 difference in supplies
    Good Day all,
    wanted to know if there is a difference with the Riso masters for the riso EZ 220
    A customer is showing me a master from a riso dealer that has a cup on one end and another
    almost the same without the cup. Is there a supply number for the one with the cup?
    mdm
