Risograph drum ink issue
  • wingclubportland
    [Misc] Risograph drum ink issue
    I have a Gr1700 risograph printer with a Bright red ink drum that i picked up about 2 months ago. i basically cleaned the whole drum inside out and purchased a new ink tube that is an off brand ink. After using for awhile without any issue i started to get an c 63 error that would occur occasionally and then became constant. i checked all the connections from the drum to the machine as well as the switches under the tube (from fiddling around with them i found that having the 5th out of 6 switch on made the system read it as a color cylinder). Does anybody have any idea how to fix this or even just clear/override the error?
    thanks!
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Risograph drum ink issue
    Sounds like the ink bottle switches are not operating correctly. If you got a manual see chapter 4 section 13 Ink Bottle switch assembly.
    Good luck.
