Error code T96-972
  • ldfrepairs
    • Oct 2012
    • 148
    Error code T96-972
    Replaced Junction PCB; paper feed, then error T96-972 was displayed. Can anyone advised what can be causing this error?
    drugstore-onlinecatalog.com
  • jermyth
    Riso dude
    • Mar 2011
    • 438
    Re: Error code T96-972
    More info please, make, model, why were you replacing pcb? The code says data not input, rev data storage area not initialized, this is from the RZ manual. Try reboot with holding reset key.
    Good luck.
    • ldfrepairs
      • Oct 2012
      • 148
      Riso mode is EZ-220. Replaced RF PCB due to error code T98-25.
      After replacing RF PCB then T96-972 is displayed.
      • jermyth
        Riso dude
        • Mar 2011
        • 438
        Which RF pcb did you replace? Ink or master? Recheck your connectors. Try turning on while holding the reset key until unit is done rebooting.
        Good luck.
        • Sriyanjan
          • Apr 2015
          • 79
          in test mode 9874 for protected area settings then 1193 1197 (or 1198)
          Sent from my HTC Desire 820s dual sim using Tapatalk
