Brother 4750e (Paper Jams)
  • Matty54
    • Dec 2011
    • 15
    [Jamming] Brother 4750e (Paper Jams)
    Getting paper jams every time I try to print. It stops in the same place every time (right at the fuser exit rollers-lead edge). I've tried everything. HELP!!!
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Brother 4750e (Paper Jams)
    I can't picture the machine in question. Is it a Fax 4750 ?
    If they share the same exit roller section as the little Fax-2820; the exit rollers ware an don't apply enough pressure to exit the pages. There was a exit roller spring modification for the Fax 2820 /2920 ect back in the day. Look for the obvious flag sensor or broken cover hinges.
    I don't know if I help you or not.
