Brother FAX 2920 Fuser Differences
  • ricmartinho
    • 142
    Hi!
    I need some help identifying the fuser for a Brother FAX 2920. I know there is a old style (LM6723001) and a new style (LM6724001) fuser but how can I identify which one is on the machine?
  • ricmartinho
    • 142
    Re: Brother FAX 2920 Fuser Differences
    Are the Fuser Units interchangeable? Can I replace the Old Style Fuser for the New Style fuser?
      when ordering the fuser from the brother portal.. if it comes up and gives you a different number ( other P/N discontinued ) then yes it will replace the older model fuser. most times they know about an issue... make a new fuser with a new part number.
      • ricmartinho
        • 142
          Hi!
          where did you get those numbers? they are not the ones listed in the PM...
          what country are you in?
            that is a 230v fuser .. currently on BKO LM6314001
